Old 12-04-2014, 12:52 PM   #1
blindmanwatching
Drives: Vitz
Wiring to the OBD plug is typically very trivial. That vintage is ISO9141, so there is one (K line) wire that is the communications wire.
Pin 16 is constant 12 V power
Pin 4 and 5 are grounds
Pin 7 is SIL, which is a direct connection to the ECM
Pin 13 is TC, which is a direct connection to the ECM
An OBDII reader communicates with the ECM via pin 7, which is the "K Line". For a standard OBD reader, just 4,5,7 and 16 are needed. Pin 13 is a toyota specific diagnostic wire.
Thanks for the response.but on the ECM end, where will all these wires be connected? or will only pin 7 be connected to one of the pins on the ECM?
blindmanwatching is offline   Reply With Quote
Old 12-04-2014, 07:42 PM   #2
7 and 13 are the only ones that connect directly to the ECM.
Old 12-05-2014, 01:33 PM   #3
blindmanwatching
Drives: Vitz
Ok. And are there any connections to the different sensors of the car...or does pin 7 and 13 provide all the data from the ECM to OBD2?
Old 12-05-2014, 10:08 PM   #4
With ODBII the diagnostic tool just talks to the ECM and the ECM does all of the talking to the sensors.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 09:02 AM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-06-2010 12:25 AM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 04:32 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
