Old 12-31-2014, 10:18 PM   #15
CoryM
Drives: 2009 5-door, 5-speed
Track tires with RS3 I run 40psi up front and 55psi in the rear
If I run R1R, I run 30psi up front and 45psi in the rear.
Just curious, how did you end up at those pressures? Maximize front grip, then tune rear to suit driving style?
My car runs about 10psi more up front than rear in HS and HS-R. Obviously I need more front pressure to keep the edges alive with stock springs, but the car savagely understeers if the rear pressures are any less than 10psi lower than front.
Also, how bad is the extra weight of the 225s and do you get enough heat in them every run?
Thanks.
Cory
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 11:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-16-2013 12:44 AM
fnkngrv's custom trailer build log fnkngrv Off-topic / Other Cars / Everything else Discussions 5 10-12-2012 02:24 PM
Build Your Yaris, toyota.com artyin General Yaris / Vitz Discussion 3 05-03-2006 05:52 PM
