![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Hey guys,
I have a serious problem. Whenever I launched my car or dump the clutch, the engine bangs against the firewall. I'm now afraid that I may break something. My friends told me changing the rear engine mount to a solid mount would solve the issue. Another option would be an engine damper however I can't find any for my car. What do you guys think?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
Your friends have the right idea. It sounds like the mount(s) are busted.
You can purchase a universal tq damper or one from another vehicle and fabricate custom brackets. U can use a piece of pvc piping or paper towel roll to determine where you want to mount the damper and what length damper to purchase. I believe there are 2 different length dampers available. |
Sounds like a plan, I'll see what we can do
micro image sells the TRD transmission mount. Might be worth it if your hard on the drivetrain. An engine damper only slows the movement of the engine.
Thanks much, could you post a link to it plz?
2ZR swap. DO IT! Ask how!
http://shop.microimageonline.com/TRD...RIS-trd-mm.htm
There should be a link to the lower trans mount at the bottom of that page. |
Thanks much, Looks like I need to do some saving.
I have an idea that will be a lot cheaper.....don't launch the car or dump the clutch
#9 | |
Mr. 155 and climbing
Might be mistaken, but I think that I got the last dogbone TRD trans mount that Garm had. He still has the 2 engine mounts. rather than fabricating mounts why not look to get used ones if you don't wanna buy new? Have you checked ToyotaPartsZone.com for OEM?
P.S. Yup, I am still alive and kickin, haha
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
I filled my engine mounts with 3m urethane lol The engine moves but not a lot like when it have the oem mounts. Also there is a little vibration when the car is at idle. For 30 bucks I think is the best you can do. lol
yup the 3m urethane works good and the vibration is not bad at all. almost no one but me notices the vibration
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
I'm going with the 3M this weekend if it doesn"t work engine damper My luanches at the track are bad and burnout also... to much torque
R-CaT Project Yar 2ZR |
#14 |
Did you fill all the mounts or just the one at the back?
#15 |
I fill the transmission mount and the back mount also. I have some pictures of the entire process. I post them later.
#16 |
HacKers WanTed!
Great!!! Love to see pics also
#17 |
Sorry for the delay.
This is the urethane that I used. ![]() To remove the transmission mount you need to remove the battery and the battery bracket. It's easy to remove. You need to put a jack stand to hold the engine and then remove the mount. To remove the back engine mount you don't need a jack stand. ![]() ![]() Before ![]() After ![]() I don't have pictures of the back engine mount but it's much easier to remove that the transmission one. Also you need to let the urethane cure 24 hours.
#18 |
Really appreciate the posts mario
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Can I change my yaris engine from 1.3L to 1.8L | Rami yaris | Performance Modifications | 9 | 06-11-2012 10:21 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| 90% on short trip. What to do to protect engine? | lh59 | DIY / Maintenance / Service | 22 | 12-17-2008 09:02 AM |
