Old 02-21-2015, 03:28 PM   #1
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
Reliability results after 6 years of ownership.
Hey all... Haven't been here in quite a while. i just wanted to share my experience with the reliability of the Yaris after 6 years of ownership. I am totally thrilled by the reliability of the Yaris (knocking on wood now). I bought my 2007 Yaris in Feb. of 2009 with 19k miles and now have 165k on it. Other than oil and manual trans oil changes, I have done only the following:
-front brakes (twice).
-one rear tail light bulb.
-donut gasket in exhaust replaced.
-bearing in alternator making noise (replaced alternator).
That's it !
I also replaced the belt when I changed the alternator, as I figured I might as well while I'm doing it. I can't remember which brand I bought, but it is junk. I have had to tighten it 3 or 4 times because it stretches.
Other than that, I have done a few mods over the years, some of which were good and some not so much...
-short throw shifter- took it out, didn't really work well.
-Installed power door locks and windows from A1- Would not recommend. Lock system didn't work very long. Power window system is still working well, but, on the whole, I don't think it was worth it.
-removed module for daytime running lights- This was to keep me from driving around at night thinking my lights were on when they were not.
-Added spacers to tilt seat back to offer more support to back of legs and for added leg room. This worked well (I'm 6' 4")
-Removed block of foam from under carpet next to clutch pedal (it was interfering with my big left foot).
Again, super excited about how few problems I have had. It is what keeps me still driving this car- six years is a record for me, some cars I only kept for months.
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 02-21-2015, 05:16 PM   #2
bronsin
bronsin's Avatar
Awesome!
The Best Is Yet To Come!
Old 02-22-2015, 07:57 PM   #3
nookandcrannycar
Awesome!
Yep. After replacing the alternator at just over 159k, I went from 160k to 300k just replacing tires, 1 serp belt (replaced original), 2 batteries, a few bulbs, 1 set of spark plugs (replaced originals), a parking break adjustrment/dust blowout, oil/filter changes, washer fluid, added half a container of coolant purchased from the dealer, and (as a precaution) had the control arm bolts replaced. I also added a cabin air filter to that 'empty from the factory' () location. Don't think I left anything out.
Old 02-23-2015, 09:32 AM   #4
bronsin
bronsin's Avatar
Didnt a wheel bearing go at some point?
Might have been somebody else though...
Old 02-23-2015, 09:48 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have replaced 3 wheel bearings now since I bought mine new in 06 and the chassis like I said has only 100k on it. Mayhaps it was me you were thinking about?
Old 02-23-2015, 02:43 PM   #6
bronsin
bronsin's Avatar
I only recall one set of bearings going, whoever it was.
But man how did three go on yours?
Old 02-23-2015, 09:50 PM   #7
nookandcrannycar
Yeah (front wheel bearings), but that wasn't during the 160,000 mile 'marker' to the 300,000 mile 'marker'...not during that range...it was at just under 111,000 miles. I think the only other replacements at the under 160,000 mile mark = tires, oil and filter changes, a few other bulbs (total bulbs over the life of the car = each headlight twice and the rear LP light twice], replacing the stolen (in New Orleans) passenger side mirror cover, and replacing the original battery.
Last edited by nookandcrannycar; 02-23-2015 at 10:10 PM. Reason: forgot battery...remembered after folding clothes (dryer cycle ended)
Old 02-21-2015, 05:54 PM   #8
fourbangingfun
fourbangingfun's Avatar
How often have you changed your manual tranny fluid and motor oil? And what kind did you use? Also front pads twice but no rear shoe replacement at all?? Interesting.
'07 @ 145k, myself.
fourbangingfun is offline   Reply With Quote
Old 02-21-2015, 05:58 PM   #9
fnkngrv
fnkngrv's Avatar
I have 100k on my rear brakes now and still no replacement. I change tranny fluid about once a year personally.
Old 02-23-2015, 09:43 AM   #10
lenzomaru
lenzomaru's Avatar
Drives: 07' Yaris S & 89' Mazda 323 LX
wow u change that really often, is there a reason?
"Cooler than the other side of the pillow"
lenzomaru is offline   Reply With Quote
Old 02-23-2015, 09:47 AM   #11
fnkngrv
fnkngrv's Avatar
because I am always and forever futz8ng with the damned car...lol. seriously, I have been doing stuff requiring the engine or trans to be pulled every year since 2010 so it is typical for me to do something that requires a drain or losing some fluid. Also with the high rpm that I run the car I am just paranoid so like to change it when I change my oil once a year.
Old 02-23-2015, 09:15 AM   #12
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
interesting that you should mention adding spacers to give higher leg room. i've been thinking of doing that same thing myself. it worked good in my old honda fit.
El Kapitan is offline   Reply With Quote
Old 02-23-2015, 09:59 AM   #13
lenzomaru
lenzomaru's Avatar
I see water pump issues popping up often when i read on other forums, what are u guys' experience with this?
Old 02-23-2015, 02:35 PM   #14
bronsin
bronsin's Avatar
09 wp went ~25k miles.
40k now...
Old 02-23-2015, 10:37 PM   #15
nookandcrannycar
I'm still on the original water pump at 300,000+ miles, but I think that is pretty unusual. Like trini_per4mance (another member), I made it over 300,000 miles on my original brakes. Trini made it to 400,000 miles on his original brake pads...amazing...considering the way he drives in his YouTube videos . Trini's original water pump lasted 502,000 miles .
Old 03-03-2015, 01:28 PM   #16
lenzomaru
lenzomaru's Avatar
hmmmm..I wonder if he is from Trinidad and Tobago like myself?
Old 02-23-2015, 10:08 AM   #17
IllusionX
Drives: 07 Yaris Sedan Aero
Mine failed at 56000km, at 2 years 10months.
Old 02-23-2015, 10:09 AM   #18
mario98c
mario98c's Avatar
My Yaris is almost 6 years also. The only thing that I've changed is the brake pads because I beat the hell out of this car racing it in track events. Other than that, the car has not broke anything.
Toyota Yaris reliability mkaresh DIY / Maintenance / Service 296 02-06-2017 02:40 PM
Two years ago today..... bentjazz General Yaris / Vitz Discussion 6 12-18-2012 10:46 AM
Official: MERCURY is DEAD after 71 years. Kal-El Off-topic / Other Cars / Everything else Discussions 15 06-06-2010 02:06 PM
Toyota Claims Ownership of Fan Wallpapers drbilal General Yaris / Vitz Discussion 11 11-18-2008 10:08 PM
Will We Still Love Our Yarii in 10 Years? redyaris General Yaris / Vitz Discussion 28 03-14-2007 01:34 AM
