![]() ![]() Drives: 07 hatchback Join Date: May 2012
Look for the sensor attached to the intake tube. It has a hose running to it and out of it as well as an electrical connection. That should do you. You can also use the brake booster hose(might be the same hose) or the pcv hose but this will have some oil and moisture in it
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| HVAC dripping water when AC on. Drain hose is NOT clogged. | kustomrtr | DIY / Maintenance / Service | 3 | 09-07-2014 09:45 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| vacuum hose / heater hose size | cali yaris | Performance Modifications | 12 | 05-17-2013 09:58 PM |
| Where is are all the vacuum hoses sourced? | LtNoogie | Performance Modifications | 1 | 05-17-2009 04:22 PM |
