Originally Posted by CTScott
You can't see it without removing the Wiper tray and battery. I use a 1/8" plastic rod to poke through and snake out. What tends to happen is that you poke through the grommet and then hit the back of the plastic piece that supports the Y on the harness, or you poke though and hit the back of the battery.
Attachment 55039
thanks for the picture CTScott, so I'll have to poke a hole through the grommet ? not able to remove the grommet itself ?
Trying to feed the temperate probe wire through for the CIPA mirror install :/
