Find wire that shows ground when car is armed.
I need a source that is switched ground when car is armed. I would tap the aftermarket alarm "ground when armed" but it doesn't appear to work.
Grab the blue wire on pin 21 of connector D33 of the main body ECU (which is the connector on the back side of the under dash fuse panel).
Is this the connector im looking for?
![]() or This? I cant even reach back there to feel the connectors.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 03-04-2015 at 06:14 PM. |
The picture is not displaying. But, if you go up the back side of the under dash fuse panel, there is one connector just above the label on it.
I see this connector.
No. it is physically on the back of the box way at the top. You have to reach/look about 8" above where you are.
I feel one plug, way at the top. So little room or slack to work with even to unplug.
#8 | |
I used the blue wire, next to the green door unlock. Opposite outcome of what i need.
It might help if i say what im using it for. Im installing DEI 516L (Voice System) One wire from its harness, says when grounded and kept grounded makes the system say (arm and be prepared for any door/sensor violations) and when it doesnt see ground it says (disarm) Right now, when i arm my alarm by remote it says (disarm) and vice versa. Even more annoying is even using the physical door lock buttons, or even manually locking the door, it speaks, and the voice system is "armed" and ready to look for door violations.
#10 | |
Odd that it is showing grounded when unlock instead.
I just read it wrong when I looked at it quick. There is nothing I can find with the correct polarity. If you want, I can make you a special version of the device that I use for the Scion IQ hatch switch mod to do the inversion for you. You'd be looking at about $15 shipped for it.
Cool workaround. But looks like the module would arm, even when im locking the doors with the switch. Can something be made to use the lock/unlock wires to show ground/no ground respectively.
Im not sure why the after car alarm's "ground when armed wire" for the starter killer isnt working.
#14 | |
My module does use the lock/unlock wires to make the GWA signal. The problem with those wires is that they are pulsed, not held, so you would just get the signal for a second and then it would go away.
the manual for the car alarm that i have says that particular wire is Ground when Armed.
Yup, i first tried the lock wire, and noticed it is pulsed when instead i need held, or it'll say arm then disarm real quick.
It looks like my module might be the best option. It's too bad that the alarm doesn't have the option of having that input reversed (+ when armed).
| Found this 2014 Mitsubishi Mirage ES yesterday | Hershey | Off-topic / Other Cars / Everything else Discussions | 97 | 01-30-2014 11:30 AM |
| Testosterone: The New Synthetic Oil | bronsin | Off-topic / Other Cars / Everything else Discussions | 23 | 12-15-2013 06:02 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 02:14 AM |
