Old 05-10-2015, 10:18 AM   #1
ra1410vi
Drives: 2012 Yaris
Yaris 2012 Electric Power Steering Warning Symbols
Hii.. I have bought used Toyota Yaris 2012 Automatic 1.3 L Car in Jan 2015.
Recently, by mistake, Light was on while car had been switched off. Resulted in its battery discharge. When I tried to plug Key and start car. It was showing few symbols, which I later discovered for Electric Power Steering Warning Symbols. Somehow, I started my car using Jumper and battery from other car. I took to change my battery. I discussed the mechanic, they said, the warning light will go off.
Problem is that when I insert my key, then only it shows the Power Steering Warning symbols. When car is on, and is running, no more this warning symbol appears.
Please share your experience if you have come across similar issues.
ra1410vi is offline   Reply With Quote
Old 05-10-2015, 10:40 AM   #2
EzziE
Smoke 'em
EzziE's Avatar
Drives: toyota vitz 2011
Hi, Ezzie here. You got no problem there, trust me if the steering wheel light was on after the ignition, then you would have a had a serious problem. I have a 2011 Toyota Yaris and the sensors do light up when you rotate the key and take it upto the ignition mode. Just make sure it doesn't light up after the ignition.
EzziE is offline   Reply With Quote
Old 05-10-2015, 12:49 PM   #3
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
bulb check
All the bulbs light up when you first start your car to let you know that all your bulbs work. No worries
alanwagen is offline   Reply With Quote
Tags
electricpowersteering, eps warning, yaris2012
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 03:57 PM
