Old 05-13-2015, 02:14 PM   #1
2009Toyotoad
Drives: 2009 Yaris 3dr
Yet another Foglight install thread
I've read several of the fog light install threads, even seen a Youtube video on one with a really good Combi stalk install using OEM part number #84140-52151 and relay #90987-02027. What puzzles me is why I can't find the OEM or TRD fog light kit. the best I've been able to find is an ebay JDM fog light kit.
Unfortunately, I can't use the switch location for the switch in the JDM kit because I have both the Bluetooth and Toyota VIP alarm indicator use the otherwise vacant spaces in the center console for the 2009 MY.
So the plan is to have a pro install the JDM kit with the Combi stalk and Toyota relay, as I'm not up to dealing with the clock spring to remove the steering wheel/airbag assembly.
Has anyone else done the fog light install using the combi switch and factory relay? How many hours are needed? I ask because my "pro" does not know and I'd like an guessimate before commiting the funds to buy the parts.
2009Toyotoad is offline   Reply With Quote
Old 05-13-2015, 09:23 PM   #2
This is how I installed my switch (and how the Micro Image plug and play foglight kit was setup):
If you use a switch (or the OEM combination stalk) and the OEM relay, the only other thing you need is a set of the pins for the under-hood fuse box connector to install any set OEM style.
The attached PDF shows the install of the Micro Image kit. Following this procedure the installation should not take more than 2 hours.
Micro Image 06-11 Yaris Plug-n-Play Fog Light Kit Installation.pdf
Old 05-14-2015, 01:11 AM   #3
2009Toyotoad
Thanks, In the event that Garm has no more kits will this work with the ebat JDM kits?
Old 05-14-2015, 07:10 AM   #4
I have never seen the JDM kits or their install docs, so I am not sure.
Old 05-16-2015, 03:05 AM   #5
2009Toyotoad
Still have not heard back from Garm. I did find something interesting though, the Toyota part number for the Wiring harness with fog lights. 82112-52430 where as the one without foglights is 82112-52420.
Old 05-16-2015, 08:45 AM   #6
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
Hey, I know it's not 100% correct but when I installed my wires from my fogs into the fuse box I used one normal push-on-lug and it slid very snugly over the 2 pins in the fuse box. It's been a year and no problems and I just used the rear fog light (which I never use) relay and moved it to the front fog lights relay position. But we rarely ever have foggy days
MedMantle is offline   Reply With Quote
Old 05-19-2015, 07:32 PM   #7
M4One
Drives: 2007 Toyota Yaris Hatchback
I got the kit from Garm and just wanted to double check. Not all the wires from the switch are needed to be connected? Just wondering what the green and brown wires are for?
M4One is offline   Reply With Quote
Old 05-19-2015, 11:20 PM   #8
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
They are for the LED of the switch itself. You're supposed to splice them into the dimmer rheostat connector. You can choose if you want to connect them or not, though personally I don't think it's really necessary, because you have an indication in your dashboard whenever you activate your fog lights.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 05-20-2015, 12:20 AM   #9
M4One
Okay, thanks.
Old 05-20-2015, 03:21 PM   #10
The PDF that I posted above shows the connections for the two light wires. They are to show you where the switch is, not if the lights are on.
Old 05-26-2015, 10:06 PM   #11
M4One
So I finally got around to installing the fog lights from Garm and as expected with my luck, they do not work. I connected the lights using yellow with yellow and the gray wire with the beige wire. The ground wire is tight and so are the connections to the fog light themselves. The only possible problem I might see is that one of the wires going into the fuse box came loose when I was installing them, but I clamped it back down and it should be okay.
Would it still be possible to install using a different method? What would happen to the wires that I use the splice connectors on?
Old 05-26-2015, 10:22 PM   #12
In that mode, the headlights need to be on and in low beams for them to light up.
Old 05-26-2015, 10:26 PM   #13
M4One
I have the head lights on and nothing. Even tried with the high beams on. Nothing. I don't what I've done wrong Am I suppose to add a fuse?
Old 05-26-2015, 10:29 PM   #14
You should check to make sure it is present in the under-dash fuse panel (FR FOG). Also, I assume you added the relay?
You can bypass the switch assembly using a jumper wire (or paperclip) between the yellow and beige wires. If the relay and fuse are installed you should hear the relay click when you jump those two or flip the switch. If you do, then everything inside the car is fine and the issue is under the hood.
Old 05-26-2015, 10:40 PM   #15
M4One
There is no fuse. Should be blue 15? Hopefully that is it. Need to go buy. Thanks for the help Ctscott. Hopefully I won't need to bug you about this problem again.
Edit: That was the problem. No fuse. Thanks a million Ctscott for your help and the instructions.
Old 05-26-2015, 11:40 PM   #16
M4One
Just realized there is a bit of gap between the lights and covers. Should I be worried about water getting in?
Old 05-27-2015, 06:08 AM   #17
The gap is normal. The lights themselves are sealed.
Old 05-27-2015, 08:15 PM   #18
rapev-8
Drives: toyota
CTscott i have the same set up as you but last year my mirco image fog lights stop working!!!! the fog light indicator light also stop working on the dash. anyway you may have an idea where to look trouble shoot it? BTW i have the same switch as you posted on top
rapev-8 is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 07:57 AM
2007 Sedan HU, Amp, Speaker install Crackerballer In Car Entertainment + Electronics (audio / video / alarm) 15 11-14-2011 08:47 PM
Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) Nips In Car Entertainment + Electronics (audio / video / alarm) 8 03-18-2011 01:42 AM
