This is how I installed my switch (and how the Micro Image plug and play foglight kit was setup):
If you use a switch (or the OEM combination stalk) and the OEM relay, the only other thing you need is a set of the pins for the under-hood fuse box connector to install any set OEM style. The attached PDF shows the install of the Micro Image kit. Following this procedure the installation should not take more than 2 hours. Micro Image 06-11 Yaris Plug-n-Play Fog Light Kit Installation.pdf
#2 | |
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
![]() Drives: 2009 Toyota Yaris Sedan Join Date: Jun 2017
Finally find the installtion guide here! Extremely helpful!
Thank you very much!! |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| DC header, AEM cai and MI lightweight crank pulley install | aspro | Performance Modifications | 7 | 09-02-2014 06:57 AM |
| 2007 Sedan HU, Amp, Speaker install | Crackerballer | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 11-14-2011 07:47 PM |
| Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) | Nips | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 03-18-2011 12:42 AM |
