![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
Yet another Foglight install thread
I've read several of the fog light install threads, even seen a Youtube video on one with a really good Combi stalk install using OEM part number #84140-52151 and relay #90987-02027. What puzzles me is why I can't find the OEM or TRD fog light kit. the best I've been able to find is an ebay JDM fog light kit.
Unfortunately, I can't use the switch location for the switch in the JDM kit because I have both the Bluetooth and Toyota VIP alarm indicator use the otherwise vacant spaces in the center console for the 2009 MY. So the plan is to have a pro install the JDM kit with the Combi stalk and Toyota relay, as I'm not up to dealing with the clock spring to remove the steering wheel/airbag assembly. Has anyone else done the fog light install using the combi switch and factory relay? How many hours are needed? I ask because my "pro" does not know and I'd like an guessimate before commiting the funds to buy the parts. |
This is how I installed my switch (and how the Micro Image plug and play foglight kit was setup):
If you use a switch (or the OEM combination stalk) and the OEM relay, the only other thing you need is a set of the pins for the under-hood fuse box connector to install any set OEM style. The attached PDF shows the install of the Micro Image kit. Following this procedure the installation should not take more than 2 hours. Micro Image 06-11 Yaris Plug-n-Play Fog Light Kit Installation.pdf
Thanks, In the event that Garm has no more kits will this work with the ebat JDM kits?
I have never seen the JDM kits or their install docs, so I am not sure.
Still have not heard back from Garm. I did find something interesting though, the Toyota part number for the Wiring harness with fog lights. 82112-52430 where as the one without foglights is 82112-52420.
#6 | |
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
I got the kit from Garm and just wanted to double check. Not all the wires from the switch are needed to be connected? Just wondering what the green and brown wires are for?
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
They are for the LED of the switch itself. You're supposed to splice them into the dimmer rheostat connector. You can choose if you want to connect them or not, though personally I don't think it's really necessary, because you have an indication in your dashboard whenever you activate your fog lights.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
Okay, thanks.
The PDF that I posted above shows the connections for the two light wires. They are to show you where the switch is, not if the lights are on.
So I finally got around to installing the fog lights from Garm and as expected with my luck, they do not work. I connected the lights using yellow with yellow and the gray wire with the beige wire. The ground wire is tight and so are the connections to the fog light themselves. The only possible problem I might see is that one of the wires going into the fuse box came loose when I was installing them, but I clamped it back down and it should be okay.
Would it still be possible to install using a different method? What would happen to the wires that I use the splice connectors on? |
#12 | |
I have the head lights on and nothing. Even tried with the high beams on. Nothing. I don't what I've done wrong Am I suppose to add a fuse?
#14 | |
You can bypass the switch assembly using a jumper wire (or paperclip) between the yellow and beige wires. If the relay and fuse are installed you should hear the relay click when you jump those two or flip the switch. If you do, then everything inside the car is fine and the issue is under the hood.
#15 |
There is no fuse. Should be blue 15? Hopefully that is it. Need to go buy. Thanks for the help Ctscott. Hopefully I won't need to bug you about this problem again.
Edit: That was the problem. No fuse. Thanks a million Ctscott for your help and the instructions. Last edited by M4One; 05-26-2015 at 09:52 PM. |
#16 |
Just realized there is a bit of gap between the lights and covers. Should I be worried about water getting in?
#17 |
The gap is normal. The lights themselves are sealed.
#18 |
![]() ![]() Drives: toyota Join Date: Feb 2011
CTscott i have the same set up as you but last year my mirco image fog lights stop working!!!! the fog light indicator light also stop working on the dash. anyway you may have an idea where to look trouble shoot it? BTW i have the same switch as you posted on top
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| DC header, AEM cai and MI lightweight crank pulley install | aspro | Performance Modifications | 7 | 09-02-2014 06:57 AM |
| 2007 Sedan HU, Amp, Speaker install | Crackerballer | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 11-14-2011 07:47 PM |
| Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) | Nips | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 03-18-2011 12:42 AM |
