Old 05-22-2015, 09:40 AM   #2
shepd
Drives: 2007 Yaris 5 door RS
Go to another dealer (since the one you went to is incompetent) and ask them for repair wires for that harness (for most connectors, wires/pins can be removed and new ones added in their place), or a new repair connector for it (these generally come with a short length of wire, with this you can replace the entire unit). They exist for pretty much every wiring connector, and most certainly for any that are external. They will need to spend some time, but they can find it for you.
If you don't want to do the work yourself, a competent dealer would be more than happy to effect repairs. There's no way it would cost $1200 to repair a single connector.
Failing all that, if CTScott is checking the forums, he'd know the part numbers for you. :) And might be able to sell you parts.
shepd is offline   Reply With Quote
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 07:32 PM
Southern Streets Presents Kami Speed Invasion 1.5 Southeast 34 09-08-2013 11:17 AM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 12:33 PM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 06:31 PM
