Old 05-27-2015, 09:55 PM   #1
BentSpace
Drives: 2009 Yaris Base
Thank you. I'll let you know. Is it possible though to fix this connector with what I have?
BentSpace is offline   Reply With Quote
Old 05-27-2015, 11:11 PM   #2
If you can splice the existing wires back together and waterproof them (heat shrink tubing) you would be OK. The questing is if you have enough wire coming out of the connector to make the splice.
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 07:32 PM
Southern Streets Presents Kami Speed Invasion 1.5 Southeast 34 09-08-2013 11:17 AM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 12:33 PM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 06:31 PM
