Old 07-06-2015, 01:08 PM   #1
davislau
Drives: 2007 Toyota Yaris Base Sedan
Thanks for the reply CTScott. I don't have a proper gauge set. What do you think my next step is? Is my only option to take it to a mechanic?
davislau is offline   Reply With Quote
Old 07-06-2015, 06:18 PM   #2
That or buy a gauge set from Harbor Freight for $35.
Old 07-07-2015, 11:50 AM   #3
esse10
Drives: 2009 yaris 2 door
A/C system
I just finished replacing the complete system in my vw new beetle and that system had a bad compressor, the low was too high and the high was too low. ctscott is correct you need to put both gauges to see what the system is doing, the high and low side . My guess is your compressor is shot ; if your low side stays high and the high side stays low while the compressor is engaged and the radiator fan is spinning then your compressor is bad. Also at this point it seems you might have over charged the system and so you put in another variable in the mix.
Tags
a/c, air conditioning, compressor, freon
