#1 | |
![]() Drives: '08 Yaris Hatchback Join Date: Jan 2015
As for getting to the point where you can remove most of the paneling, this video is pretty helpful for the general idea: https://www.youtube.com/watch?v=0o6Epf0Cfo8 You will be able to get everything off (including the main three screws) except for a plastic push insert that's located on the door by where your sideview mirror is. Once all the screws are out, I was able to gently pull the paneling forward towards the bottom and back of door to pull out the push inserts, and then lift up the paneling towards the back of the door and pull forward, revealing a gap, from here you can squeeze your hand in (be careful, I ended up with a number of scratches on my hand from this) and find the latch release near the bottom of the actuator. If you've never done this before, I'd suggest taking the paneling off the other door so you understand how it's held in place, and practice finding the latch release where you have plenty of room. Once you get it open and take out the actuator, all the reading I did suggested that you just need to clean the copper leads on the motor to get it working again. I took it apart, cleaned the leads, and the motor started working for me again, but I ended up buying a refurbished replacement on eBay anyway (putting the actuator back together can be tricky). Good lucK! |
#2 | |
![]() Drives: 07 yaris Join Date: Dec 2010
Alright, so my actuator came in (turns out it's mechanical only, no electric like mine, but as long as it works I don't mind that. Plus it looks like it has the space for the electric parts, they just arent in it). And upon playing with it... I still fail to see how I will be able to take out my current stuck actuator.
The internal unlocking mechanism isn't working. The lever at the bottom doesn't open the door. EDIT: Alright, I have found a small piece that I can turn with a 10mm wrench that will unlock the new actuator; I have yet to try it on my car but I will post an update later for anybody else that has this problem. Below is a picture of what I am talking about: UPDATE- Alright, so I grabbed a massive pair of pliers and just crushed the mechanism, taking chunks out at a time, until I got down to the bare door mechanism. This allowed me to upen the door and switch out the actuator assembly. Everything is switched out and working great, thanks guys! Last edited by cry0; 07-27-2015 at 10:59 PM. Reason: Update |
| Tags |
| actuator, door lock actuator, door stuck, locking mechanism |
| Lights indicate hatchback is ajar, but it is closed | RMcG | DIY / Maintenance / Service | 6 | 05-10-2013 05:10 PM |
| Closed | Per Kristian | Cosmetic Modifications (Exterior/Interior) | 0 | 04-05-2011 05:17 PM |
| BLITZ HAS CLOSED????? | ROCKLAND TOYOTA | General Yaris / Vitz Discussion | 12 | 08-13-2009 06:35 AM |
| Why is DTM exhaust thread closed? | gr8yaris | Performance Modifications | 4 | 01-13-2007 12:01 PM |
