Old 08-16-2015, 09:35 PM   #1
33 - Right Rear Wheel Speed Sensor Signal
34 - Left Rear Wheel Speed Sensor Signal
39 - Foreign Object is Attached on Tip of Rear Speed Sensor LH
94 - Control Module Communication Bus OFF
Old 08-18-2015, 12:24 AM   #2
trojjanhorse
Drives: 2007 Yaris LE
Thanks Scott. I opened up the two small harnesses that cage the rear sensors and sprayed contact cleaner. The wires seem fine to me on inspection. I think my problem is a bit more deep seeded. This all happened post rust-proof. Do you have any idea or advise as to what I should do next?
Thank you
trojjanhorse is offline   Reply With Quote
