Old 08-18-2015, 09:04 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
You can port match the intake manifold to the 1zz TB. Thats was done to the one i got.
And i also have the Tooter spacer. I can tell you with the Spacer/Manifold port matched to the 1zz TB and AFE intake, i have no oscillations and high rpm at cold start promptly drops to operating idle rpm quickly.
Check out my Build thread:
Old 08-18-2015, 10:15 PM   #2
Rigaud
Drives: 2009 Yaris
True and all good points. However the 1NZ entire intake is designed and sized for a smaller flow. Port matching the hole for the TB does help, just not getting the full flow of a 1ZZ intake and a proper port/polish. Much better improvements with a proper intake manifold. Also if you go bigger going in then you should replace the header and exhaust line. Me it's a custom fitted 1ZZ intake manifold, 1ZZ TB and custom made aluminum air intake. My car is in storage during winter months so this year the motor comes out for piston replacement, port/polish, 8lbs flywheel, A/F management, etc....
By the way, with just the 1ZZ TB not port matched at all and the stock air box, I got oscillation for five minutes the first day then that was it.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
FS: 1ZZ 05 Corolla Throttle Body FunctionSpec Items for Sale by private party 15 05-26-2010 04:23 PM
[Buy] throttle body 1zz yaris 1800cc to 1500cc TS Nets Items for Sale by private party 2 04-25-2010 11:27 AM
1ZZ throttle - Not Optimized Yet! fuji Performance Modifications 30 06-04-2009 01:40 AM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 06:19 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
