Old 09-04-2019, 12:43 PM   #1
ojeysky
Drives: Sedan Yaris 2010
Originally Posted by IllusionX View Post
Wasn't 20w50 what you were using before?
Your engine could be damaged. Piston ring letting too much oil sip through.
Previous owner was using 20w50 don't know for how long, so I guess I would then continue with that and plan for a change of engine in future
ojeysky is offline   Reply With Quote
Old 09-04-2019, 12:51 PM   #2
bronsin
bronsin's Avatar
I just bought a new 2020 corolla. It comes with synthetic oil, but to keep the warranty you have to change it every 5000 miles normal or synthetic oil.
My wife’s Camry is 15 years old and has 175,000 miles on it all on regular motor oil. It’s time for a new one to what advantage would using synthetic oil be?
Old 09-04-2019, 02:36 PM   #3
Brighton
Knower of little
Drives: None
There is a lot of material out there about the pros/cons of synthetics and the basic pros are; better/more additives, last much longer, holds up to stress better but costs much more than conventional. Run what you like for the reasons you like but know that changing brand, composition (additives), quality doesn't make much difference for most production vehicles. Viscosity is incredibly important though so stick to OEM Spec (unless modified, extreme climate or abnormal circumstance.)
Also I'd recommend watching Project Farms (on youtube) oil championship videos, there is a ton of good info in them.
Brighton is offline   Reply With Quote
Old 09-04-2019, 03:44 PM   #4
Hershey
Consumer Reports talks of synthetic oil , https://www.consumerreports.org/car-...l-in-your-car/ . You can get mail in rebates at PENNZOIL , MOBIL1 and other oil company websites . Some take less than a month to receive by mail . PENNZOIL Platinum and FRAM Ultra Synthetic oil filter for both cars .
Old 11-13-2022, 07:29 AM   #5
scetto3000
Drives: 2012 yaris le 4dr hatch
Airplanes do not change oil, only change filters when light comes on. Then fill to full. Knowing this I change my oil every 5000 miles, but i also change my filters every 1,000 to 2500 miles. Keeps the filter fresh and never allows it to go into bypass mode. lowers the contaminents and it doesnt add much to maintenace costs when I buy filters 12 at a time and use an extra 6 /year.
scetto3000 is offline   Reply With Quote
Old 11-13-2022, 07:32 AM   #6
scetto3000
toyota manual says it may burn up to a qt per 1000 miles. never had that happen. was amazed they accept that as normal. never burned a drop until at least 150,000 on any model i had.
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 02:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
