Old 04-18-2007, 11:10 AM   #24
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Originally Posted by PetersRedYaris View Post
People fail to maintain their cars properly ,including tire pressure, and this is the reason for the focus on underinflation. If you neglect your tires, eventually the pressure will drop creating a dangerous situation. This is a COMMON problem. Overinflation is not a common problem as tires do not spontaneously jump up in pressure. Someone has to overinflate them on purpose. I'm sure after this "hypermiling" trend becomes more well known, and a few 60 PSI tires blow violently causing mayhem on the freeways, the danger of overinflation will spark a few tire pressure studies focusing on overinflation.
99% true, but tires do increase pressure on their own as temps increase (you probably already knew that). I've heard that for every 10degree F increase, the tire pressure goes up 1 lb.
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 10:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 12:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
