![]() Drives: 2008 Yaris Hatchback Join Date: Sep 2015
i wonder if you can upgrade the clutch in the earlier years? Someone has asked that question somewhere. I am sure.
![]() Drives: 2007 Yaris LB Base Join Date: Jun 2015
same issue with my '07. When you turned on the a/c, launched much easier!
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Yes you can upgrade. Get a stage 1 preformance clutch, well worth it. I installed a stage 2, forgot what brand but I'll look it up and post later unless someone else who did the same chimes in.
Exedy Stage 1
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
I test drove a manual...and bought an automatic!
Despite the claims that an auto is less fun to drive, I have a great time driving mine. It has enough pick up and if I really want to get involved in shifting gears, I just do so with the auto; but the nice thing is when I'm stuck in traffic, I don't have to deal with that awful clutch!
#10 | |
#11 | |
are they any tech writeups on this forum on how to R and R a clutch on a 2008?
I did a search and couldn't find one |
#14 |
The awful clutch, together with the laggy electronic throttle, cramped seating position and footwell, uncomfortable seats, and lack of tachometer makes the car the least fun/comfortable manual transmission cars I have ever driven.
#15 |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
Looks like you should look at the 15 models. ALL of these areas have been greatly improved. The seats are incredibly comfortable. As comfortable as my Avalon Limited.
#16 |
Good to know! I heard they swapped out the clutch for '15, which is great. I am not in the market for a new car, but a '15 Yaris will be a great buy in the future, it sounds like.
#17 |
![]() ![]() Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
To replace the clutch in the Yaris, do you have to remove the engine? How much should the clutch replacement cost on average?
#18 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
I don't think anyone has actually touched on why the Yaris clutch sucks so bad. The reason is because there is absolutely no feel right? When wearing workboots I literally cannot feel the engagement point of the clutch because the pedal is so light. The main reason for this is the diaphragm spring on the pressure plate are very light. This is the essentially the part that your foot is pushing against (after a bit of hydraulics and leverage). So get a clutch with heavier diaphragm springs would make a big difference. As mentioned before, performance clutches feel better because they have heavy diaphragm springs to give better clamping force on the clutch disc. I have not tried one in a Yaris yet, but it should make a world of difference in pedal feel. A performance clutch is probably a very good idea for people who just want better clutch feel than OE. That being said, I don't know that I want one in my car I've learned from past experiences that clutches are cheap compared to transmissions. From much higher horsepower cars than the Yaris, but I typically run weak clutches in my cars so that the clutch breaks before the transmission etc. Clutches are cheap compared to hard parts.Cheers. Also, this is an excellent video on how clutches work: https://www.youtube.com/watch?v=pqF-aBtTBnY |
