Old 11-22-2015, 12:14 PM   #12
tmontague
tmontague's Avatar
Easiest way it to buy an ultragauge (or other scan tool) and set it on short and long term fuel trim while the car is idling. Then Rev the car to 2500rpm an see how the values change.
If the long term trim is showing a high positive # under idle but not at 2500rpm then it likely has a vacuum leak.
You should hear a his from the area that is leaking. I personally light a stick of incense and watch where the smoke is being sucked into on the engine to find the specific area of a leak.
Keep in mind after resetting the ECU your engine will idle a little erratically for a few hundred km's
Tags
erratic idle, idle, idle problem, wandering idle
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Fix For Low Idle When Warm On A Yaris Mk1 danielbb DIY / Maintenance / Service 0 06-12-2014 04:13 PM
rough idle.... dindy Third Gen Yaris General Discussion 5 06-12-2013 12:48 PM
3rd gen 1zz tb swap mr_miles DIY / Maintenance / Service 26 05-01-2013 08:20 AM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
