Old 12-12-2015, 11:01 AM   #1
harda toenail
Drives: Want a yaris
Just out of curiosity- do you bump your key forward and let go to let the car start itself, or do you hold the key forward until the car starts?
harda toenail is offline   Reply With Quote
Old 12-12-2015, 08:09 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I usually hold the key until the car starts, but not a moment longer, so I'm 100% sure I'm not holding too long (if that's what you're wondering).
I've never read about it anywhere, but are we just supposed to click the key once and let these cars start themselves?
Old 12-12-2015, 08:54 PM   #3
Yes. There is no need to hold the key until the engine catches. Just turn to start the crank, then let go. I call it twist and release.
Old 12-13-2015, 01:33 AM   #4
ern-diz
ern-diz's Avatar
Okay, good to know, thanks. I realized it worked that way, but thought it wasn't the proper thing to do and worried about premature wear doing it that way.
Originally Posted by scoobopdan View Post
Not sure if this helps, but I had a similar sounding issue with my 08 yaris. Right after the last turn over, when the car started, it would make a weird scratching/squealing noise. Turned out my starter was going and the brushes were rubbing against each other.
It does help; it's what I've been suspecting all along. Thanks for the feedback.
Vitz starting issue Xuhaib DIY / Maintenance / Service 1 10-25-2013 06:13 AM
When cold starting, almost sounds like opening a fresh 2-liter Coke bottle Shinare DIY / Maintenance / Service 8 06-03-2013 04:18 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
