Old 12-22-2015, 10:32 PM   #4
Doing the line-based flush has the advantage of being able to swap out more of the fluid than you can remove with just a drain and pan drop. If you are going to change the fluid, it really makes sense to drop the pan to change the screen filter and clean off the magnets. It will also give you a better chance to see how much debris is present.
Many people say that if you do not change the fluid regularly, you should not suddenly do so at a high mileage.
Tags
flush, radiator, transmission
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 10:46 AM
So how many miles are on your Yaris? jjonrofl General Yaris / Vitz Discussion 34 12-26-2009 01:15 AM
