Old 12-23-2015, 08:26 AM   #1
Iridium Sparkplugs Experiment
Originally Posted by nortonfb View Post
If I remember correctly; When using Never Seize reduce torque by 10%.
Really? Never heard of that.
I don't buy it. Torque would be measured by the resistance between contact surfaces, not how slippery the threads are.
Old 12-23-2015, 10:08 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The lubrication of the anti-seize reduces friction between surfaces of the threads and changes the torque. The exact same way oil inside the engine reduces friction between rotating parts. IDK about the 10% thing but usually if a torque rating doesn't call for lubrication, don't lube it.
Even with that said I only apply the smallest amount of grease to the threads so they don't rust on wheel stud. Anti-seize as I found from personal experience can drastically change the torque rating.
But on spark plugs, they aren't torqued, they are set to usually an amount of rotation to compress the gasket.
FS: Denso Iridium POWER plugs NIB "G" Items for Sale by private party 60 03-22-2013 08:11 PM
ngk iridium ix - anyone got them? GianniVRS Performance Modifications 2 11-12-2012 03:02 PM
So You Just Have To Have Iridium Spark Plugs eh? bronsin General Yaris / Vitz Discussion 32 04-17-2012 02:14 PM
Where can I get iridium spark plugs??? fidgell Canada 4 03-01-2010 12:10 AM
Sparkplugs? nsmitchell General Yaris / Vitz Discussion 23 07-09-2007 06:47 AM
