Old 12-26-2015, 07:47 AM   #2
You can climb into the hatch area, pop off the small cover in the lower center of the hatch and simply flip the silver lever to open it. Once you do, you can pull off the cover to access the entire lock assembly and see what the issue is. Typically it just needs cleaning and lubrication.
2010 Yaris Liftback (LB) / Hatchback - Prewired for Trunk Actuator? bad_bwoy007 DIY / Maintenance / Service 26 01-18-2021 06:09 AM
Hatchback Trunk Cylinders Betrivent DIY / Maintenance / Service 75 06-14-2020 06:55 PM
Where can i get a Hatchback trunk cover for cheap? Syroyizhka Cosmetic Modifications (Exterior/Interior) 19 10-29-2013 01:59 PM
Hatchback Trunk Cover KrazyDawg General Yaris / Vitz Discussion 24 11-08-2010 03:00 AM
is this trunk kit ok for our hatchback ?? vten DIY / Maintenance / Service 3 10-31-2009 03:49 AM
