Old 01-05-2016, 04:35 PM   #1
tmontague
tmontague's Avatar
I just installed the new module I was sent since the original one was not grounding the parking lights. The new one also has the same problem unfortunately. Either it's plain bad luck and Vipers quality is turning into crap (CTScott had eluded to this in his experience) or the other possibility is that for some reason I have to tap into the parking light positive wire and not negative. With the way the wires are set up in my stock connector the negative wire should work fine as others have installed it that way.
f10167, keep me updated with your experience with it and if your wiring is good (tested by the paperclip) then I have a feeling that we have to tap into the positive wire as I don't think it's a coincidence that 3 modules all have the same problem
Old 01-06-2016, 11:36 PM   #2
f10167
Drives: 2008 Yaris
Hi tmontague,
My parking light and the headlight buzzing sound came right up with the paper clip so now I'm sure that the viper module is definitely defected as I have already put the flash light fuse to negative terminal. I have already contact the seller and the replacement module is on the way.
Thanks for the feedback.
f10167 is offline   Reply With Quote
2014 Keyless Entry Install Question GMRelkin DIY / Maintenance / Service 4 03-09-2017 11:26 PM
keyless entry issues azamora General Yaris / Vitz Discussion 0 10-29-2013 08:29 PM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 10:27 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
