![]() ![]() Drives: 2012 Yaris SE MT Join Date: Dec 2012
Greetings Yaris Owners,
This build has the usual goals: Sound Quality: Tight, accurate bass that would sound good regardless of whether it's hip hop, EDM, vocals or orchestra music, and anything else No rattles Bass energy focussed on the two front passengers Kick in the back Easy to move around System flexibility/No compromise with regards to space Stealth to avoid attracting unwanted attention Hopefully sharing this build with the Yarisworld may spark some ideas for others for their own builds. Positive constructive comments are welcome ![]() Calculations and planning:
is this going in a HB or Sedan?
All I care about is that rotor in the first picture. BRAP BRAP BRAP. I miss my RX7....
#5 | |
This:
![]() Quote:
That's the dented rotor from my first blown engine. Yeah, I miss it too. ![]() aaand... the 17.4 lbs. of boost on a new engine with new Efini turbos ![]() Built a stealth system in the RX-7, too ![]() ![]() ![]() We're back on topic in the next post
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
I am so loving this so far. I have an 8" sub in a prefab box which was made for 2 subs that takes up my whole boot. I'm also in the process of making a stealth setup that's gonna look OEM. May even upgrade the 8" kicker for a 10" while I'm busy to get the best of both worlds :P \m/
![]() ![]() Drives: 1nzfe Join Date: Jan 2016
A little Focal might sound better.
Hot stuff! I reckon I wanna see your build complete though for some inspiration as I am a total novice when it comes to woodwork etc.
#10 | |
1nz revolution,
I agree. That's why I bought a a set of open-boxed Focal 3-way components for the 2003 MR-S. For subs, however, I've really been impressed with SoundQubed for their ultra-rigid lightweight cone, serious suspension, spring-loaded terminals, insane voice coil and completely exceptional quality. This HDS208 dual 2-ohm 8" woofer is rated at 600 RMS, but it easily handles closer to 1000 off a Pioneer D-class without bottoming out. ![]() ![]() Typical box-building materials. Maybe should have posted this earlier ![]() ![]() Ported enclosure mockup (for the 8" sub for the MR-S). Flush-mounted woofer, dual ports (for aesthetic symmetry) and rounded panels for improved efficiency, port aerodynamics and reduced port noise: ![]() Ported enclosure construction. Notice the rounded port channels, pilot-drilled screw holes and straight-through 12-gauge OFC wires for the dual voice coils. My dremel broke, and I didn't want to spend $40 to buy a new one so all rounded panels were actually done by hand.![]() Open-box purchase for $360 on the Focal 3-ways ![]() ![]() Removed the cheap soft rubber dust caps from the Focal 6-3/4 woofers to be replaced with homemade polypropylene caps: ![]() Quote:
Thanks! It just comes from creativity, experience and doing it right the first time, even if it means your project might take a little longer. |
A little Audison will brighten it up.
![]() Drives: 2009 Yaris 5 door Join Date: May 2015
Updates?
| Yaris Sedan Deadening and Sound system upgrade | derickveliz2 | In Car Entertainment + Electronics (audio / video / alarm) | 2992 | 11-18-2021 03:14 AM |
