01-07-2016, 04:35 PM | #145 |
01-07-2016, 06:43 PM | #146 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
We have not, but I believe its the same 6spd in the newer corolla....witch has a 2zr also. Im pretty sure its compatible
01-07-2016, 11:03 PM | #147 |
Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
sorry I got lost in the details, I thought the 2zr-fae was different than the 2zr-fe?
01-08-2016, 08:52 AM | #148 |
Data doesn't lie
The only significant difference is they increased compression from 10:1 to 10.5:1(Edit: and Valvematic). Otherwise they are almost identical
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-08-2016 at 11:16 AM. |
01-08-2016, 08:57 AM | #149 |
01-08-2016, 08:58 AM | #150 |
01-08-2016, 10:23 AM | #151 |
Data doesn't lie
.... the question was about transmission compatibility haha....but thanks for the info!
01-08-2016, 06:58 PM | #152 |
Data doesn't lie
Started disassembly today
01-08-2016, 07:04 PM | #153 |
Is the car stuck in a lot right now, or is this where you work...??
01-08-2016, 08:49 PM | #154 |
2ZR swap. DO IT! Ask how!
It's an automatic? So sad. =P
On a semi-related note, the engine harness ECU pinout for the xD is wildly different from the Yaris. Like, 99% incompatible. I haven't documented the smaller connector yet, but it will likely be different, too. The actual component connectors, however, seem to be identical, if named/numbered differently. E.g. the engine bay wire harness ECU connector is C20 in the Yaris, but C19 in the xD. Edit: just compared the connections on the 60-pin ECU side--about 90% incompatible. Both connectors are incompatible in possibly catastrophic ways for the ECU. Moral of the story: DON'T SWAP ECUs WITHOUT SWAPPING WIRE HARNESSES! Last edited by CrankyOldMan; 01-08-2016 at 09:50 PM. |
01-08-2016, 10:19 PM | #155 |
Data doesn't lie
Im a Tech at the dealership...
Yes it is a auto, because its my only car and Im not trying to teach my pregnant wife manual.....i have a 5spd on standby for when we have a second car. We swap everything over from the Xd, EVERYTHING lol. Regarding the diy...do I need to include pulling the 1nz? Or just the assembly and install of the 2zr?
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-09-2016 at 12:03 AM. |
01-09-2016, 07:01 AM | #156 |
Drives: 2007 Toyota Yaris Join Date: Nov 2015
Just a quick question regarding swaps since that's the subject here
Why doesn't anyone swap the 2zz into the yaris? Edit: the more information the better |
01-09-2016, 08:07 AM | #157 |
Drives: Yaris 07 HB Join Date: Apr 2011
I think only assembly and install of the 2zr. There are manuals and videos in the web to how dessembly de 1nz.
01-09-2016, 08:08 AM | #158 |
01-09-2016, 10:09 AM | #159 |
Drives: 2009 Yaris Join Date: Jan 2014
That and it's NOT a plug and play for the ECU. Been done with success by some in Europe and Asia. Crazy motor but a big project for those who dare.
01-09-2016, 01:32 PM | #160 |
Data doesn't lie
AND the fact that the 2zz is crazy expensive....I actually considered this swap before the 2zr untill I added up all the related costs. $2000+!
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-09-2016 at 03:16 PM. |
01-09-2016, 11:34 PM | #161 | |
unplug and remove 1nz plug and install 2zr =enjoy 30whp+ gain whats all this talk about the wiring being 99% incompatible ????? |
01-10-2016, 12:02 AM | #162 |
Data doesn't lie
@Crankyoldman was referring to using the 1nz harness on the 2zr. I never once suggested that, Ive said from the beginning to use everything from the 2zr. The 2zr engine harness plugs into the 2zr ecm on one end along with the chassis harness, and it plugs into the fuse box at the other end. Sinmple.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
