Old 03-02-2016, 07:22 PM   #1
Remove the lower steering column cover (two screws that become visible when you turn the steering wheel to one side and the other, and one screw by the tilt lever), then unplug the two connectors at the base of the wiper stalk. Drive for a couple days that way and see of they come on. If they do it is the wiper motor, if they do not it is the stalk.
There are no other relays, other than the ones that are built into the stalk.
Old 03-02-2016, 08:13 PM   #2
lopat08865
Drives: 2008 Yaris HB
Roger! Shall do!
From what I read here, was hoping you'd be among the ones who replied :-)
So simple and sure a troubleshoot w/no upfront outlay of $. Let you know how it turns out. Thanks!!!
lopat08865 is offline   Reply With Quote
Old 03-09-2016, 11:08 AM   #3
lopat08865
Nice try but no go. Ideas?
Disconnected wiper arm stalk & replaced it with a used one. No reoccurrence of problem for 2 days then it happened again today.
Thought about replacing wiper motor but decided against it because I've been persuaded that the problem lies exclusively with the washer function. Why? The wipers are SUPPOSSED to come on whenever the washer functions, so it's a washer problem, no?
So I still don't know what to do. I guess it's possible the replacement wiper stalk assembly I bought on eBay is also bad. I could buy/try another used one [or new from Toyota for $165].
Made a diagnostic appt w/Toyota for Friday at $107/hour. Really, really hoping someone here has something better to try!
[PS: Toyota parts confirmed what CTScott said: there is NO other relay for the wiper than what's in the stalk. They thought it sounded like a "Spiral Cable" a/k/a "Clock Spring", which parts out at $715 before labor ... ouch!]
[PPS: First occurrence of the problem was the morning after I drove home in the rain. FWIW, I probably turned car off without turning the wipers off. As I say, FWIW.]
Old 03-09-2016, 07:32 PM   #4
Gotta love wrong info from the dealer - The wiper stalk does not route through the spiral cable.
If the stalk did not fix it, then I suspect a pinched wire. The green wire to the washer motor gets grounded to make the washer run when this occurs the logic within the wiper stalk also makes the wiper run. If that green wire is damaged somewhere between the washer motor and the stalk it could be getting intermittently grounded.
Old 03-09-2016, 07:43 PM   #5
lopat08865
Thanks again for the quick response :-) Sounds very promising. Since it's an intermittent problem I guess there's no way to test it, I would need to track and replace the entire run of this wire?
Old 03-09-2016, 07:46 PM   #6
I would start with checking the end under the hood, that goes to the motor. You may simply find an area where it had been rubbing and the insulation is worn.
Old 03-09-2016, 07:55 PM   #7
lopat08865
Quick search seems to show motor attached to reservoir at left front of engine compartment. So that's where I can ID the green wire to start tracing it for inspection?
Old 03-09-2016, 08:40 PM   #8
Correct.
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 01:52 PM
2012 Yaris Sedan - Wiper Blade Sizes mcastill66 DIY / Maintenance / Service 1 02-04-2015 08:41 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
About hand wash and other methods.... zyovka Wash, Wax, Detailing, Exterior Repairs 5 09-27-2006 05:10 AM
