![]() Drives: 2002 ECHO Join Date: Aug 2014
Am sitting in my 02 Echo on break @ work. Stock 1.5, rear sway, kyb struts & shocks , Pirelli P4 185 on stock steel rims.
My major snivel is the auto tranny. Way slow on gear changes.big pause in response to throttle input. Anj upgrade wouls be sweet. LOVE it otherwise. |
#2 | |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
Sent from my LG-D801 using Tapatalk |
#3 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#4 | |
I used to mainly drive manual in the past. I also go into neutral at lights or when cruising downhill :-) |
| FS, toyota echo rs cluster 80$ cad | echo-francis | Items for Sale by private party | 1 | 12-17-2015 10:38 PM |
| 2004 toyota echo sportive turbo need help!! | sportivoecho | Performance Modifications | 7 | 11-02-2015 06:34 PM |
| 10 cool facts about toyota | soap94 | Off-topic / Other Cars / Everything else Discussions | 0 | 11-02-2015 10:20 AM |
| my Toyota echo | ipwnr | Off-topic / Other Cars / Everything else Discussions | 11 | 03-31-2014 09:07 AM |
| 1st Post.New Owner 04 Echo HB 2Dr 5Spd A/C | mpcv2000 | Canada | 2 | 11-11-2013 09:30 PM |
