![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Clunk noise on a bump when on speed
Hi All,
I am experincing a confusion here On a road with 8 - 9 bumps on single bump i hear a clunk noise from rear of the car. I am unable to figure it out where it is. Car is running fine and no funny noises on other roads. I like to mention this particular road is on steep hill with loads of bump I am sure not many to standard construction. But noise is from rear side Can the experts help here where to look what Yaris 2005 99k cheers |
make sure your shocks aren't wet looking indicating they're leaking. Then look for loose parts.
Check to make sure the mounting bolt on bottom of rear shock is tight. I once had a loose one that on visual inspection appeared tight but was loose enough to creating clunking noises over bumps.
Which one can u pls advise
Sent from my GT-I9195 using Tapatalk |
Thanks I will check tihs weekend what size they are 12?
Nothing found but i noticed on a certain hump i got clunk from any car at speed >25m
If less than 19m than its all ok
Thanks I lube it and tight all four.
No funny sounds now. |
| DIY Cruise Control for 2012 Yaris - Good News! | CTScott | Third Gen Yaris General Discussion | 305 | 10-27-2025 01:52 PM |
| Yaris sales hit new low... | Kal-El | Third Gen Yaris General Discussion | 131 | 10-18-2025 11:59 AM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| Irritating Door Noise | Anakha56 | Third Gen Yaris General Discussion | 1 | 04-21-2013 11:06 PM |
| Noise from rear of Yaris | APS67 | DIY / Maintenance / Service | 5 | 09-25-2011 06:51 AM |
