![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
I used ToyoDIY . com in the past but it doesn´t have the diagrams anymore, but you can search under the powertrain group the word "brake".
Also many dealerships with online stores do the same and show the parts assembly diagrams, even the price. |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Both of the rotors on my Yaris warped like crazy. I've never had rotors warp like that on anything else. I've been using the el cheapo ones on my truck for the last 4 years and haven't had any trouble out of those, so that's what I went with on the Yaris too.
I use Wagner Thermoquiet pads - http://www.amazon.com/Wagner-ThermoQ...ilpage_o05_s01 And these rotors - http://www.amazon.com/Centric-Parts-...ilpage_o05_s00
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
If you are looking to go performance you could always swap on the Yaris S stock rotors with a set of xD/corolla calipers and pads. I just did that with the MI stainless braided lines, and wow. I wish all my vehicles stopped like that. I hardly even have to press on the brake pedal anymore to get response.
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Yeah I am looking for a bump in braking performance. To me the car doesn't really brake well with the stock components.
However, while I would like to gain some braking performance, I'm not sure I want to change the pedal feel much. I like actually having to feel it go down some. And I think you can increase braking power, without having an over sensitive brake pedal. I used to have an 03 Volvo S80 and it was like that for some reason. You breathe on the pedal and it would jam on the brakes. Didn't like it. It would make your foot sore, because when you'd want to hover over the pedal for a bit, you couldn't just slightly rest your foot on the edge of the pedal. If you did that the car would be braking pretty hard. Harder than I thought it should for the amount of foot pressure that you put on the pedal. So if possible, I'd like to avoid that outcome with the Yaris. And it seems to me, there should be a way to do it. Perhaps its just a pedal adjustment. |
I wouldn't say that it is over sensitive at all, more so responsive. It actually feels right. I don't feel like I have to put weight into braking now. It still has plenty of pedal movement, without being touchy. It just brakes effortlessly. I like it that way.
I rest my foot on the pedal without issue at all. In my previous comment, I didn't mean to make it sound like it was twitchy, just really does what I want. |
Anyone happen to know the brake fluid change interval? Probably in my manual but I heard toyota can be a bit weird about this so I thought I'd ask. Just in case there are any odd requirements to changing the brake fluid in my 09 Yaris.
The car just reached 150k miles, so I was going to go ahead and do a brake fluid flush while I'm doing all this work to the brakes. |
I don't believe the manual states a regular interval for brake fluid bleed.
I would change it out due to your mileage, I change mine every 2-3 years and it looks fine at 2 years. The fluid will absorb moisture over time so even if it looks fine it should be changed periodically. You can purchase an electronic tester which will measure the moisture in the fluid as well.
Mine has the original fluid from 2008 in it. It still looks brand new.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 10:03 AM |
| brake and rotors | the_boss | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 03-23-2011 10:18 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 05:43 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 08:16 PM |
