09-04-2016, 05:44 AM | #1 |
Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
ATF flush after 45,000KM
i finally flushed my ATF after 45,000KM..some people say you dont need to flush them or change them at 100,000km etc...
i rather flush them out and put fresh fluid since i down shift often or shift through gears on my automatic transmission.. after we took out the fluid with them sucking machine thing, it was pretty burnt and dark af... gear shifts much smoother and feels much better after the fresh atf... rather safe than sorry..enjoy!! 😆😆😆😆
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem Last edited by rabbito; 09-04-2016 at 11:47 PM. |
09-04-2016, 12:30 PM | #2 |
Drives: 2013 Yaris Hatchback L Join Date: May 2013
Do you have a transmission cooler installed? Given you manually shift your auto, better safe than sorry.
09-04-2016, 01:57 PM | #3 | |
no, i dont have them installed..😂 Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem |
11-02-2016, 11:54 PM | #4 |
Drives: 08 Yaris HB Join Date: Aug 2009
I think your automatic transmission should already have a stock cooler by the radiator. (at least I assume the AT Yaris has one). I never really looked at the yaris for a cooler. On my AT 4runner it is built into the radiator ( I had to swap it out a couple months ago). But this was a good reminder that I should probably go ahead and swap my fluid in the Yaris. I am a little over 100,000 so def due. But now I will look for the cooler while I am under it out of curiosity.
What kind of transmission fluid did you use? I was just going to go with Toyota atf ws but looks like you used something different in the pic? |
11-03-2016, 12:00 AM | #5 | |
i mean its only $50 here with the labor...not even a labor, machine with a sucker that just sticks in..i will just change mine every 40k...😅 Sent from my SM-J710F using Tapatalk
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Complete flush for ATF change? | Lance16 | DIY / Maintenance / Service | 29 | 07-05-2017 09:26 PM |
Transmission Flush / Coolant Flush at 60k? | ttpmurphy | DIY / Maintenance / Service | 7 | 08-29-2015 09:39 PM |
Replaced my ATF | markitect | DIY / Maintenance / Service | 6 | 01-02-2014 10:10 PM |
ATF Drain and Fill | DMZ | DIY / Maintenance / Service | 7 | 05-30-2013 11:01 PM |
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? | lejulie | DIY / Maintenance / Service | 14 | 10-23-2011 07:43 PM |
