I don't have all of the wiring diagrams for the MK1 European Yaris, and the MK2 ones have a different passenger occupancy detection system than our US ones do, but I believe on the MK1's that the passenger occupancy sensor is just a switch. This switch which feeds the info to the SRS ECU to determine if the airbag should fire in a crash.
#2 | |
airbags
Because the US 2nd gen (aka MK2) Yaris has a occupant classification system for the passenger seat, which actually measures the weight of the passenger at four points between the seat and seat frame and uses that data to determine if the airbag should be armed (and if the seatbelt should be buckled)
![]() Drives: BMW Join Date: Aug 2016
So is the passenger airbag bypass plug still available anywhere, or at least a circuit diagram? I've just joined the ranks of super-impressed Toyota customers with a possible IED dashboard, and apparently UK models don't have an off switch either.
____________________________________ Vape mods |
![]() Drives: 2008 Yaris 2-Door (White) Join Date: Jan 2014
Replacement Inflators Are In
While letters are not out yet, the replacement inflators are now in stock/arriving at Toyota dealers. Had the recall closed yesterday afternoon on my wife's 08 hatchback here in Knoxville.
![]() Check with your local dealer; you too may be able to make this recall history. |
#6 | |
| Passenger airbag light on making turn signals and cabin fan not blowing? | thatbryanguy | General Yaris / Vitz Discussion | 17 | 08-16-2024 11:23 AM |
| Passenger Airbag Question | RedStickHam | DIY / Maintenance / Service | 13 | 06-23-2013 05:39 PM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 09:20 AM |
| Passenger side airbag question | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 01-03-2009 08:54 PM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 08:22 PM |
