you can use a volt meter to check the continuity through the LED. they do burn out sometimes. then check continuity on wiring harness. then from fuse to battery power source.
| Tags |
| cel, check engine light |
| Check Engine light on after Water Pump change | gumby002 | DIY / Maintenance / Service | 3 | 03-19-2014 09:06 AM |
| help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 06:17 PM |
| check engine light, engine turns but not start | willygoodness | DIY / Maintenance / Service | 10 | 07-23-2012 05:10 PM |
| Check engine light | Geelmeel | DIY / Maintenance / Service | 7 | 11-28-2009 11:32 PM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
