Old 12-09-2016, 01:28 AM   #1
roachslayer
Drives: 2013 SE
I'm a little shocked by the claims in this thread about 30 MPG+ in city, and even 40/70. What?? Either I'm reading this wrong, or I've got quite a different setup.
Here is my situation:
  • 2013 Yaris SE, 4 door
  • Auto Trans (don't laugh, its the only way the wife would go for the Yaris)
  • 34k miles
  • 85 octane gas
  • 5000 ft elevation
  • 23 MPG City (according to Yaris computer)
dunno about hwy yet, nor have I calculated my own fill ups to compare with what Yaris thinks - haven't owned it long enough. But assuming the computer is even in the ball park, this is a far cry from what folks are claiming here, no?
roachslayer is offline   Reply With Quote
Old 12-09-2016, 01:31 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
  • 34k miles
  • 85 octane gas
  • 5000 ft elevation
i was getting 11-12km on normal gasoline..octane 91...-_-
now about avg 10km with E85...sometimes more than 12km on the highway...
Sent from my SM-J710F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 12-09-2016, 03:04 AM   #3
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
  • 34k miles
  • 85 octane gas
  • 5000 ft elevation
Is this gasoline you are using E85 which is bio ethanol ?
Ethanols consumption is said to be 30% more than normal additional gasolines !
If so then your readings are not bad at all !
KimmoKekki is offline   Reply With Quote
Old 12-09-2016, 09:57 AM   #4
roachslayer
Drives: 2013 SE
EDIT:
No, it's not E85 bio. It's just petrol (which apparently is mixed with maybe 10% ethanol around here). I run 85 octane because that is normal at this altitude. When I lived at sea level the lowest you could buy was 87. (Utah vs Seattle, WA)
Tags
automatic, manual, mpg
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 10:57 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 06:02 AM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 07:14 PM
