01-12-2017, 10:53 AM | #1 |
Drives: 07 yaris Join Date: Dec 2016
Led headlights?
Just wondering if the newer type led's with the heat sink on back will work in the h4 yaris headlights? Since the h4's have that rubber seal around the back of the bulb. And a good bright reputable led if anyone knows what brand is good!
01-12-2017, 11:12 AM | #2 | |
Drives: 07 yaris hatchback Join Date: Dec 2016
Sent from my SM-G935T using Tapatalk |
01-12-2017, 11:47 AM | #3 |
Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
No problems fitting it into the Yaris' cramped space?
Sent from my LG G2 with CM13 using Tapatalk |
01-12-2017, 11:49 AM | #4 |
01-13-2017, 10:56 AM | #5 |
01-13-2017, 11:10 AM | #6 |
01-13-2017, 12:51 PM | #7 |
i had them in my echo...no issues. H4's in my wifes old Kia Soul, too....no issues
www.facebook.com/kitchenerHID
01-13-2017, 02:39 PM | #8 |
How much brighter than the stock halogens were they?
01-13-2017, 02:40 PM | #9 | |
I take a picture tonight and post it
01-13-2017, 04:22 PM | #10 |
Drives: 2013 NCP130 Join Date: Nov 2015
Even more important that brightness - how do these affect the light pattern? Most LED replacements I have seen for other globes have the LEDs covering a different area to the original globe filaments. This can significantly change the pattern of light output. Worst possibility with the headlights is to dazzle other drivers and possibly cause an accident.
I look forward to seeing the photos of the light output.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
01-13-2017, 06:13 PM | #11 |
Low High High Low Low Low High Low High I hope this works Sent from my SM-G935T using Tapatalk |
01-13-2017, 08:31 PM | #12 |
Thanks. Great photos. I will have to get some of these and try them.
01-13-2017, 08:52 PM | #13 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I'd love to see how they look from an incoming direction. Up close they seem like they have a decent cut off but from any kind of distance they shed a lot of bright light up top even on low beams.
I'm all for brighter lights but in almost every case I've seen anything brighter than oem needs a projector or else they blind other drivers and tell "I do half assed mods to look good but screw other drivers" They may actually not be bad at all tough to tell though without seeing them in person. They are much better than oem. So many cars in my area throw in led's or hid's and skip on projectors to "save money" and they make it impossible to see.
No one ever wants to give a Yaris the point by... |
01-14-2017, 01:15 AM | #14 | |
Drives: 2014 Yaris SE Join Date: Apr 2014
01-14-2017, 01:01 PM | #15 |
Headlamp bulbs are a PITA to replace in a Yaris, and you basically have to take the bumper/cowl partly off. So I would like to only use LED replacements from now on, but just with regular brightness. Is that not possible?
01-14-2017, 01:23 PM | #16 | |
01-14-2017, 08:07 PM | #17 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Check out the picture below of how it looks onwards. Note: Driver side needs allignment. Any DIY guides on how to do this? This thing is, reflector housings were never designed for brighter output. The cut-off will always be washy. The same thing will happen if you change your OEM bulbs with brighter halogen bulbs. If you trully want a poper cut-off, then a projector retrofit is the only real way to go.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
01-15-2017, 01:24 AM | #18 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Do a proper HID projector retrofit. Anything other then a HALOGEN bulb in a housing designed around a HALOGEN filament and the way it produces light is going to be a downgrade and reduces safety for you and other motorist. You basically paying to downgrade the car.
My favorite halogen bulb that I ran in my sedan prior to HID projectors was the Osram Nightbreaker. Powerbulbs.com sells em for a great price and I absolutely loved them. However nothing beats properly engineered HID projectors with excellent cut off and more even light beam
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Having a few very very odd issues after LED conversion | Astroman | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 08-03-2014 05:53 AM |
Does anyone realize yarisworld is getting 'less busy'? | caineroad | General Yaris / Vitz Discussion | 84 | 11-05-2013 12:19 AM |
FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video | V70R_Blackbrick | California | 4 | 10-13-2013 10:57 PM |
Yari gets a sway bar and a rim change (again) | D&D | Photo-Video-Media Gallery | 8 | 09-16-2013 01:10 AM |
Cruise Control kicking itself out | GTBaker | Third Gen Yaris General Discussion | 9 | 09-05-2013 09:39 PM |
