Old 01-23-2017, 07:22 AM   #7
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Hello
As per the repair manual
DTC P0420 is detected when the vehicle is driven at an average vehicle speed of approximately 50 km/h (31 mph) with a city driving pattern for approximately 30 minutes, and then driven for approximately 15 minutes at a constant vehicle speed of between 70 km/h and 90 km/h (43 mph and 56 mph) with the transmission gear selector lever in the 5th position. (If the engine speed remains 1900 to 3400 rpm and the engine load remains 25 to 50 % after the catalyst is warmed up for 60 seconds or more, the detection for DTC P0420 will be performed)
I havent seen a bad (new) cat but check for a bad (new) sensor B1S1 and B1S2. Pins ok in the plugs ? Maybe loose?
I can post the proccedure if you want but you will a Toyota THS2 or similar to increase or decrease injection volume so you can check the response from the sensors .
ncp13 is offline   Reply With Quote
Help and Advice please Code - P0141 and P0420 bechdan DIY / Maintenance / Service 16 07-15-2014 05:28 AM
Hmmm...P0420, eh? Jcp123 DIY / Maintenance / Service 4 03-14-2014 05:39 PM
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
Cat lovers, Cat haters, this is a MUST READ *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 10-14-2012 06:20 AM
High flow cat question AzNguy Performance Modifications 2 12-20-2009 05:51 PM
