Old 01-25-2017, 06:08 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
^ outlet flange bolt pattern is wider for the yaris and the outlet is in a slightly different position. You can probably use one...just modification to your front pipe will be needed.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-26-2017, 12:04 AM   #2
Elwe2k
XP10 Enthusiast
Elwe2k's Avatar
Drives: 2000 Echo Coupe
You mean like replace the bolt pattern with another aftermarket pipe? or maybe adapt the OEM outlet flange? I was thinking about adding a aftermarket pipe and/or exhaust from newer models and customise to fit....
'01 Yaris 5dr Hatchback M/T | Blue Streak Metallic [RIP]
'00 Echo Coupe A/T | Absolutely Red [Still Alive]
Elwe2k is offline   Reply With Quote
Tags
exhaust manifold, exhaust wrap, weapon r, weapon-r
Yaris dead then minutes later starts fine vinny121 DIY / Maintenance / Service 6 02-27-2015 08:01 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Shiny glass-looking plastic flakes from HVAC, and windshield LugNut New YARIS Purchase Forum 15 11-20-2011 10:39 AM
