Old 02-01-2017, 12:15 PM   #1
Originally Posted by ern-diz View Post
Yes, the OEM springs may go sooner than they would at stock height
shocks/struts
Old 02-01-2017, 08:57 PM   #2
BennyLava
Drives: 1987 Silverado
To reiterate, I and several others here are running the Tein S Tech springs (approx. 2" drop) with stock struts/shocks. No issues whatsoever. Quality of ride actually improved for me. Yes, the OEM springs may go sooner than they would at stock height, but there are fairly cheap replacement options available for when that happens.
Thanks! I'll probably just use the OEM stuff until/unless I run into an issue. But that still makes me want to ask:
Are there "lowering" shocks/struts available? Ones that are designed for to be able to not wear out faster on a lowered car? There must be some out there that won't be affected at all by lowering the car.
Or in some cases, shocks/struts off of a different vehicle or model are actually what is needed. For instance, on my '95 mustang, if I want to lower the car 2", I need to use shocks off of an '86-'93 mustang. They are somewhat shorter, and therefore their range of operation is suited to a lowered 1995 mustang. If you use those, you won't be bottoming out the shock, it will perform as though the entire setup came on the car from the factory.
BennyLava is offline   Reply With Quote
Old 02-02-2017, 12:59 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
shocks/struts
Yes, thank you for correcting.
I haven't dug too deep into replacement shocks/struts yet because I haven't had to, my OEM's are still crisp, but I am subscribed to the following thread about available shock/strut options:
http://www.yarisworld.com/forums/showthread.php?t=55770
Others can correct me because I'm far from an expert, but I don't think there are "lowering" shock/strut options specifically, but there are/were stiffer options that provide a sportier ride and reduce travel, making them better for performance/lowered setups.
From my light reading about it here on the forum, the preferred choice was from Tokico (red and blue models), but apparently they're no longer made. Per the link I shared above, KYB seems to be a cheap, OEM compatible option that are +60k miles in and going strong for some folks. Furthermore, some claim the TRD's are actually re-branded KYB's.
If you do some more research, or testing on your own car, please share your findings on the post I linked above.
On Instagram
On Wheelwell
Old 02-03-2017, 12:46 AM   #4
BennyLava
Ok I will thanks.
There used to be a long thread here, that was just a lot of lowered sedans. Is that thread still around? Anyone got a link? I didn't see an actual gallery here.
Old 02-03-2017, 08:13 AM   #5
Only sedan specific thread that I've ever been aware of. http://www.yarisworld.com/forums/showthread.php?t=1482
Right there is the sticky portion of the photo gallery forum.
Old 02-06-2017, 07:12 PM   #6
BennyLava
That seems to be the general consensus, so it looks like the answer is no. You don't really need different ones unless yours are worn out. And then you might go with KYB's or some such.
I do know that KYB is/has been the OEM supplier of a great many manufacturers. They just paint them black instead of white with a red KYB logo.
Old 02-06-2017, 08:59 PM   #7
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
Body Kit Questions JohnnyBomber101 Cosmetic Modifications (Exterior/Interior) 5 05-21-2011 12:18 PM
Some 2011 body questions hoggster Cosmetic Modifications (Exterior/Interior) 3 03-08-2011 12:49 PM
The Upgrade is done, couple questions regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 05-02-2009 06:25 AM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 11:40 AM
