imo, if you do the work yourself and have properly inspected the buchings and they do not have telltale signs of wear then I'd only fix what is broken/almost broken.
If you're paying to have the work done then I'd do it all at once since it will save a lot on labor. Keep in mind that many aftermarket parts do not last nearly as long as oem so I wouldn't recommend just swapping out parts (unless you bought oem) because you have them unless you see that they are worn or are showing signs of wear. Control arms bushings (the puck bushings at least) you can usually see wear when you jack the car up and there is no load on the suspension. You'll see smaller cracks forming - more than what is normal for rubber bushings. This is what I have on my Yaris at 175k km. Just my 2 cents but some things to consider none the less As a side, what's the story behind your username....scares me a little bit...
| Excessive vibration over 60mph. Suspension related? | Aclosefriend | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-29-2016 07:06 PM |
| Which hand tools needed to replace shocks/struts? | detroiter | DIY / Maintenance / Service | 9 | 04-24-2014 12:25 AM |
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 10:26 PM |
| Confort suspension for TS? | shtou | Yaris TS Talk | 0 | 06-16-2011 02:27 AM |
| NSW Proposed Suspension Restrictions | Bella | Australia | 0 | 09-22-2010 02:51 AM |
