Don't know why yours is so stubborn as it is just a pop off cap. All I can think of is that you are just being a bit too gentle. Put screw driver under it and twist the blade, not pry.
I take it that since you are proceeding with the fronts, that you have your issues/questions about the rear resolved.
#2 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
I cot the paper thin plastic cap off know.Didnt even see it there as it was so thin. Know thats solved i cannot loosen top nut without allenkey spinning. I would need a 12'' long allen key to get the leverage needed to loosen nut. Time is running out so I may put everything back together and try on the weekend. This is a lazy silly desighn. My accord was a breeze. I even put sleved bar onto allen key and have it wedget between some metal things and nut wont budge. I would need to get my impact wrench into there while holding the allen key somehow. Not sure why everyone says its an simple job? Going to fiddle around for another hour then will have local mechanic do the job.The rears are done so I may be able to get it done for a couple hundred.Atleast i tried. Last edited by Pinchlite; 02-23-2017 at 11:53 AM. |
In my experience, hitting with the impact is powerful enough to loosen the nut without needing the allen key.
#4 | |
shocks/strut
I gave it all I got so I am glad i tried for sure. If life offered me more personal time i would probaly give it another go. Its definitly a 2 day job and unfortunatly thats 2 days i never get. I will get the pros to give it a go. Thanks for the replys..much appreciated as always. |
| DIY: Rear shock, sway bar, and strut brace refit | Tapokata | DIY / Maintenance / Service | 19 | 05-31-2016 01:05 AM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| Blitz Oil Cap o-ring | 47_MasoN_47 | Cosmetic Modifications (Exterior/Interior) | 9 | 09-25-2012 10:37 AM |
| Tanabe front strut tower brace or Ultra Racing strut tower brace? | sternz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-14-2010 06:14 PM |
| C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 06:53 PM |
