The BodyArchitect
Drives: Yaris Sedan 2015 Turbo AT Join Date: Dec 2015
REAR LEFT FENDER ISSUE
so i bought some m2 lowering springs for my yaris and all of them seam to work nicely they droped 1,5" of height i can barely get 2 fingers in each fender except the rear left which i just can fit 1 finger and it touches the wheel , so i checked under the car and the springs look exactly the same compressed but i don't get why is it lower in that fender? ,so a friend told me its a "yaris thing" that he has seen many others lowered with the same problem no matter the lowering springs (eibach,H&R,tein,m2,manzo,megan) so i want to know if this is true and are there any solutions for it?
thanks |
I have heard of this before. The rear axle I think is offset a bit for some reason.
yup. my spring perches are of uneven height to balance it out. And also you may notice one wheel will be more flush and will have to use one extra wheel shim just a tiny bit.
The BodyArchitect
So there's no actual solution? I'll have to stretch my fender then so it can fit and stop touching the wheel
that sucks. i'm glad I came across this information. I would think your only solution would be to roll fender, or to buy adjustable coilovers. I now know not to buy springs.
thanks! |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
I would be more interested in having more ground clearance so my wife doesn't keep hitting curbs with bottom of bumper when parking.
The BodyArchitect
From what if heard and experienced in other cars coil overs make the car jump a lot but it does give the lowered look and stability you need
The BodyArchitect
| Tags |
| help!, issue, lowering springs |
| DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 54 | 04-24-2026 08:40 PM |
| e46 rear shock issue | Caramanos2000 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 05-19-2015 09:04 AM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
