#10 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Finally got it off by putting vice grips onto shaft then impacted it off. I ended up removing entire metal cowling support plate. The drivers side was stubborn but not this stubborn. I still think the car is resting on the bumpstop on the finished drivers side,even though I cut 1.5 inches off. The back turned out beautiful but the front is dissapointing.The drivers side is pretty much stock height. I dont care about the struts as i am putting new ones on. |
| Sway Bar End Links Help! | GiovanniVan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 03-02-2015 11:14 PM |
| How should the front sway bar be positioned when adjusting coilovers? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 03-28-2011 11:20 PM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| front sway bar install | birdman | DIY / Maintenance / Service | 5 | 10-04-2009 08:41 AM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-08-2009 11:26 PM |
