#91 |
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
Am getting confused single step double step can u explain ??
so they way off r.l bi 6" l.l bi 3 " am goin to check tonight Sent from my SM-G935T using Tapatalk |
#92 |
Sorry. Okay, you know how projectors have a cutoff? The cutoff is comprised of a lower line, slant in the middle, and continues as a higher line, so a single step. When the passenger side's lower line is at the same level as the driver side's higher line, the entire cutoff is comprised of two steps.
#93 |
so this is single stepSent from my SM-G935T using Tapatalk |
#94 |
Single step set up:
![]() Double step set up:
#95 |
That would be a double step.
It's all just preference, but I ended up going to the single step (proper way actually) from a double step. In order for me to not blind on coming traffic at the time, I had to get the passenger side along a parallel wall to be as close to horizontal as possible, and then adjust the driver side down. Well, that sacrificed some throw in favor of shining up road signs, and that just wasn't worth it to me. |
#96 |
Thank u bro I learn something new today thank u
#97 |
#98 |
Maybe u can help me with this so I put the hid h3 in but because was h4 so I connected the Lil motor for the cutoff for high beam I connected to ground of the h4 plug and positive on the highbeam plug so when I flick to high beam the hid cut off so I purchased this maybe Thas the issue?? What u think
![]() Sent from my SM-G935T using Tapatalk |
#99 |
Try unpinning the two vertical prongs on the harness (the part that plugs into the OEM connector) and switch the two and repin. Try that to see if it fixes your high beam issue.
#100 |
Ok thanks
#101 |
![]() Drives: 05' Honda S2k, 15' Toyo Yaris Join Date: Feb 2017
@yaris847 was thinking of doing the same setup without the relay. Amazon had similar products, but of course I needed to get ballasts and bulbs. I went with Kensington ballasts and bulbs and iJDMTOy easy relay harness for the bi-xenon.
#102 |
#103 | |
#104 |
#105 | |
#106 |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Update on the mini projector installation ?
#107 |
![]() ![]() Drives: Sedan Yaris 2010 Join Date: Dec 2017
I recently purchased one of these and I am having a hard time fitting the rubber seals. Any suggestions?
#108 | |
Sent from my CLT-L04 using Tapatalk |
| Having a few very very odd issues after LED conversion | Astroman | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 08-03-2014 05:53 AM |
| Does anyone realize yarisworld is getting 'less busy'? | caineroad | General Yaris / Vitz Discussion | 84 | 11-05-2013 12:19 AM |
| FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video | V70R_Blackbrick | California | 4 | 10-13-2013 10:57 PM |
| Yari gets a sway bar and a rim change (again) | D&D | Photo-Video-Media Gallery | 8 | 09-16-2013 01:10 AM |
| Cruise Control kicking itself out | GTBaker | Third Gen Yaris General Discussion | 9 | 09-05-2013 09:39 PM |
