Old 03-09-2017, 10:01 PM   #1
nate0
Drives: 2013 hatchback Yaris
Not Starting 2013 Yaris Hatchback
Hello everyone, I just had this 2013 Hatchback Yaris for about 3weeks now with 165km no accidents. It was running good until yesterday night, on my way back from work I filled up then drove home for like 20min. An hour later, someone else in the family use it to go to grocery. It all see fine.
In the morning I tried to start it. It would start for like a second or two and stop. It would do it again if I tries to crank 2-3 times. Then it would just crank after that, will not run momentarily and die.
I tried to use the quick start spray and it would start momentarily and die.
Is this a fuel pump problem or relay?
I am trying to find the relay to swap out but could not locate it.
Can someone tell me the name I am suppose to look for please?
nate0 is offline   Reply With Quote
starting problem on 2008 d4d yaris georgeg General Yaris / Vitz Discussion 15 06-13-2016 10:26 AM
Yaris 2013 engine braking problem? pikador DIY / Maintenance / Service 5 01-05-2014 04:12 AM
2014 Mazda 3 Kal-El Off-topic / Other Cars / Everything else Discussions 32 11-08-2013 12:51 PM
