Old 04-11-2017, 12:44 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The speedo gear is on the differential body, so the pinion shaft and ring gear are turning. I can almost guarantee it's a drive shaft issue. My son had the same thing on one of his cars, but because it was sheared off at the oil seal on the transmission, it looked like everything was fine.
Are you mechanically inclined to repair it yourself? If not, you need to have it towed with a dolly or flatbed. Don't try and have another vehicle tow it with a strap.
If it's sheared off inside the gearbox, you can get the stub out by removing the opposite side and using a *soft* metal bar (brass, preferably) to drive it out. If it's somewhere else, just follow the normal repair procedure.
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
