The piston came out and you likely have air in the system. Time to bleed out that corner. It is possible that you have damaged the piston seal, but probably not. After you are done bleeding, have your helper hold steady pressure on the brake pedal as if they were coming down to a hard stop. Make sure you have no fluid coming out, and the pedal height remains the same while doing this pressure check.
With brakes, pretty much any time you see brake fluid come out, you should bleed. Cheers. |
#2 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Once I put cap back on and wiped down I pushed in the 2 end pin things a couple of times and nothing leaked out,but yes I will have to bleed. Hopefully its okay to drive like this because I wont have time till weekend. |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
