Old 05-08-2017, 01:03 PM   #1
SirDigby
Drives: 2007 yaris 3 door
no. i believe you are just changing the position of the turn signal and reverse light. i might be wrong on the wire functions.
the connectors are the same. you only have to replace the connector if you damage it. if you using a simple terminal tool, or even a pick or a safety pin, you can remove the wires without damage to the connector and swap their positions. the connector is the same shape regardless of USDM/JDM/CDM/EDM/AusDM/AisaDM etc.
Old 05-08-2017, 02:16 PM   #2
Correct.
Old 05-13-2017, 10:30 PM   #3
SirDigby
ok. i am wrong. there are different connectors. maybe it is the 09 and up that are all the same. the JDM is square, where as the USDM is a long rectangle, at least for 06-08. i'm sorry for any confusion...
