Old 06-08-2017, 12:57 PM   #1
Pinchlite, how the hell can you hear the side marker ratttle with all the other noise this car makes?
The retaining clip on one of mine mysteriously snapped for some reason. Approached my car one day and the light was dangling against the fender by its wire. Secured it back in place with a small bit of 3M tape. This could be the very reason why magicman is observing a silicon bead around his.
Old 06-08-2017, 01:10 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Same thing happened to both marker lights on my 2007. I researched getting new ones... which I found dirt cheap on e-bay; instead, I made 3M gaskets for them which worked out well.
Old 06-08-2017, 01:58 PM   #3
Pinchlite
Drives: 2007 yaris HB
rattles
(I made 3M gaskets).Can you elaborate as I would like to do the same.
Old 06-08-2017, 02:00 PM   #4
Pinchlite
There is not enough metal.
The plastic light does not overlap metal enough for silicone to be of any purpose.Already tried.
I have isolated all rattles thats why I can hear this one.
I did all the engine bay rattles,door and a few others and nothing sits loose inside my car.Also rear seat delete including all seatbelts/hardware with everything sound matted.
Rattle TSB I found the other day. ToyotaTEch21 DIY / Maintenance / Service 37 05-29-2018 12:17 PM
Annoying driver door rattle Vince87 DIY / Maintenance / Service 5 09-27-2016 12:16 AM
Finally found the answer to the annoying ticking/rattling sound from inside... YarisSedan General Yaris / Vitz Discussion 2 05-10-2012 06:39 PM
Annoying Rattle 1NZYaris1 General Yaris / Vitz Discussion 20 08-24-2009 03:00 PM
